healthy ping graph
beeceegee
healthy ping graph
Since a session drop and re-connect about 2am a couple of nights ago my TBB graph is looking ridiculously healthy. I only noticed one other user affected by the drop on the graphs page. I see I am now back on ptn-bng01, which not so long ago was the one we were all trying to get off. Not complaining or anything  Wink but what happened?
SuperZoom
Re: healthy ping graph
Same here on PCL-AG05.
Much cleaner than it has been (there were lots of random yellow bits not long ago).
Web surfing generally more 'responsive' (an objective measure for which has proved elusive).
Definitely not complaining!
beeceegee
Ok so this morning around 12:15am I got kicked back onto pcl-ag04. Apart from the fact that my wife was working using a vpn connection at the time and lost a bit of work, I notice that average ping times have ticked back up to the level before I was kicked over to ptn-bng01  Sad
xreyuk
Can I ask how you find out which gateway you are on?
dick:quote
Mine's still as healthy as ever .
I really should fix that  Roll eyes
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
SuperZoom
Yeah, the greatly improved performance didn't last long here.
It's annoying because it's noticeable when it's really, really good.
Nothing untoward correlated graph-wise.
The BNG gateways have lower ping times, I believe, because they treat the ICMP traffic differently. It doesn't necessarily mean better real-world latency.
@Xreyuk
You can go here, or just do a traceroute.
xreyuk
Thanks SuperZoom
