has plusnet restricted by download speed
- has plusnet restricted by download speed
05-11-2011 8:42 PM
and my upload speed is still the same at 0.3mb. and its any time of the day or evening
http://www.speedtest.net/result/1573980792.png
http://www.mybroadbandspeed.co.uk/results/125647531.png
how long does the www.speedtester.bt.com/ take, as I have tried a few times but it never completes just hangs on the “checking user details page”
and I live in the Wombourne area code CMWOM
Re: has plusnet restricted by download speed
05-11-2011 8:55 PM
05-11-2011 9:11 PM
05-11-2011 9:45 PM
What does This Say? it should say 5.5mb or 6.0mb obviously - anything else and this could be the problem
Regards
05-11-2011 10:11 PM
Estimated line speed:
6Mb (This may vary between 5Mb and 8Mb) - Checked on 2011-11-05 21:44:42
Current line speed:
0.25 Mb
done a few speed tests in the last couple of days and there all the same
05-11-2011 10:36 PM
Current line speed: 0.25 Mb
I assume that the IP profile will be the same if you can ever get the speed test to work
05-11-2011 10:50 PM
This means you've had a low sync event (e.g. lots of interference has caused the connection to drop)
Hopefully you've not been whacked on a banded profile, as this will be much more stubborn to clear.
Speed should pick up again after a day or two of "normal" sync speed (might be worth giving the router a reboot if you havent as yet)
Regards
edit: for most people its best to do the resync event between about 8am and 2pm, as thisi s when there is the least interference so you get the best sync rate (it may however cause a further drop to a more stable rate)
06-11-2011 8:33 PM
and just done another speedtest.net check and its back to normal
http://www.speedtest.net/result/1577277724.png
6.49mb DL & .0.38 UL
Thanks again
07-11-2011 9:41 AM
so as i was going to say who do i complain to Plusnet or BT
07-11-2011 9:51 AM
What are your router stats showing now? If you're using the router we sent then this link should get them for you.
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13206593648607.png" />
08-11-2011 11:29 AM
Have tried a few tests this morning and the download speed is the best its ever been
http://www.speedtest.net/result/1580110379.png ;
my normal DL speed is between 6 & 7 mbps and today its 10mbps
so fingers crossed it stay that way and Thanks for your help
