got my router and...
- got my router and...
14-02-2011 9:07 PM
Hello,
I've got my router and I followed set up instructions which went fine, but I didnt get a set up page when I went online it just went straight online. I need to secure my wireless but i'm not familiar with vista. At the moment anyone can access. Can someone give me an idiots guide please...
thanks.
thanks.
Message 1 of 4
(781 Views)
3 REPLIES 3
Re: got my router and...
14-02-2011 9:12 PM
Welcome to the forum alexlowe12000
Does this help? http://www.plus.net/support/broadband/hardware/thomson_wireless.shtml
Message 2 of 4
(395 Views)
15-02-2011 9:00 AM
Hello,
OK thanks i'll try that. The paperwork I got with the router says that it is VERY important to only do that if you get an error message... I got no error message just google.
thanks
thanks
Message 3 of 4
(395 Views)
15-02-2011 10:17 AM
your router should have had WPA security enabled, the code is on the bottom of the router, did you enter that, if so you are secure as can be
Message 4 of 4
(395 Views)
