gone in 60 seconds?
- gone in 60 seconds?
gone in 60 seconds?
20-01-2011 6:38 PM
any help would be appreciated i have already done the reset after 20 minutes etc
Re: gone in 60 seconds?
20-01-2011 10:15 PM
can you post your router stats and the result of a bt speedtest?
20-01-2011 10:27 PM
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 444 / 16,083
Output Power (Up/Down) [dBm]: 12.0 / 0.0
Line Attenuation (Up/Down) [dB]: 15.0 / 29.5
SN Margin (Up/Down) [dB]: 30.0 / 3.5
Loss of Link (Remote): 0
FEC Errors (Up/Down): NA / 577,924
CRC Errors (Up/Down): NA / 71
HEC Errors (Up/Down): 0 / 63
Download speedachieved during the test was - 1554 Kbps
For your connection, the acceptable range of speedsis 800-2000 Kbps.
IP Profile for your line is - 1750 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 13.14:25.37:61.52 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
20-01-2011 10:43 PM
Quote from: lane182 IP Profile for your line is - 1750 Kbps
That's your problem and until that lifts you are going to be pegged at a slower speed.
It is likely that you've had a low synch event. it should recover in a couple of days.
20-01-2011 10:57 PM
20-01-2011 11:04 PM
your router dropped and had a low synch around 2000 and as your stats report it's now at 16000
20-01-2011 11:06 PM
20-01-2011 11:25 PM
Quote from: lane182 Uptime: 0 days, 3:57:59
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
20-01-2011 11:48 PM
21-01-2011 12:08 AM
21-01-2011 7:11 AM
21-01-2011 9:08 AM
