go live date
ninacab1
go live date
My go live date was the 6th November however I have not received a text to say our broadband is live.
I have tried calling however have been waiting over 40mins each time.
how can I solve this?
2 REPLIES 2
SpendLessTime
Fixes: 86
Re: go live date
Welcome to the forum @ninacab1
While you wait for a member of staff to confirm waht is happening, you can do a quick check for yourself to see if the order has a completion date.
Have a look at the BT Wholesale checker site at https://www.dslchecker.bt.com/adsl/adslchecker.welcome
Enter your phone number and look in the text below the results table.
It will say if there is an open order on your line and more importantly the date it is due to be completed.
No completion date means either it has been done or something has gone wrong with your order. Again a staff member would need to advise you.
HarryB
Fixes: 256
Re: go live date
Hi @ninacab1, I'm sorry to see your order hasn't completed as expected.
I understand you've since discussed this with someone and they've advised that they'll chase this up with our suppliers tomorrow for you.
I've tried contacting our suppliers now to see if they can give us any info this evening and I'm afraid I've simply been advised to check back for updates tomorrow as the department they need to speak to are currently closed.
I do apologise for any inconvenience caused by this delay. Thanks for your patience.
 Harry Beesley
