gigabit modem/router recommendations
- Re: gigabit modem/router recommendations
21-10-2011 12:10 PM
i am looking to buy gigabit modem/router, are there any better than others to work with plusnet, i have tried a billion 7800n could not get it to work, i return it suspecting it was faulty
Message 1 of 5
(1,040 Views)
4 REPLIES 4
21-10-2011 10:50 PM
I, and others, woud highly recommend a working Billion 7800N!
Message 2 of 5
(416 Views)
21-10-2011 11:02 PM
Why do you need it, have you got a Gigabit broadband connection?
Normal modem/router plus a Gigabit switch is cheaper, more effective and more flexible.
(the last Gigabit switch I purchased was £13.89 delivered)
Message 3 of 5
(416 Views)
22-10-2011 10:06 AM
i think i might give billion another go,i want a new router as i want to change from speedtouch
Message 4 of 5
(416 Views)
22-10-2011 10:10 AM
There is a similar thread about this - http://community.plus.net/forum/index.php/topic,98622
Message 5 of 5
(416 Views)
