getting into router
quintusIV
getting into router
I am trying to do something about the wifi speed and I have the instructions, I have to change the channel.
I do not have I.E and I need to get into the router, Google will not get me in, is there any other way I can get in?.
Thanks.
Re: getting into router
Use what ever browser you used to view this forum, type http://192.168.1.254 in the address bar then login and follow the instructions from there
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
quintusIV
Cheers Gus, much appreciated
