gateways
goatty2
gateways
is the download speed the same on all gateways?
as I moved from gateway 01 to 08  and download speed went from 36 down to 32.
or could it be that i changed router from 7800n back to the plusnet router
Fixes: 46
Re: gateways
You shouldn't really see any difference in speeds across the gateways, it's more likely to be related to the change of router or the fact you disconnected and reconnected again.
 Adam Walker
goatty2
Re: gateways
Thanks Adam
I have a new router on its way see what difference it makes
