gateway problems this lunch time? started 12.15pm 3rd Oct
- gateway problems this lunch time? started 12.15pm ...
03-10-2014 12:50 PM
I have dropped PPP about 4 times in the last 40 minutes
edit: checking my logs an oddity PPP CHAP Receive challenge (rhost = PCL-AG04) after the first one then each after it PPP CHAP Receive challenge (rhost = JUNOS), currently on pcl-bng02
FTTP 500 regrade from Tues 28th November
Message 1 of 5
(901 Views)
4 REPLIES 4
Re: gateway problems this lunch time? started 12.15pm 3rd Oct
03-10-2014 4:26 PM
Hi Gus,
We don't have any reported issues at the moment and there are no ongoing works what would cause this kind of impact. I can see the dropped sessions in the RADIUS graph below however a quick line check hasn't highlighted anything.
<img src="http://community.plus.net/visualradius/generated/image1412349783911.png"/>
Have you noticed anything else untoward with the connection since the drops?
Have you had any problems with the reconnection stalling immediately after the drop?
Message 2 of 5
(542 Views)
03-10-2014 6:05 PM
Looking at my router stats looks like I have a fault still, last engineer found corrosion on D side which he fixed and fitted the MK2 VDSL faceplate, but my CRC's are a bit high. But the weather has changed for the worse, so I will see how it goes over the next week before starting a new fault
Uptime: 0 days, 5:38:00
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 978 / 5.511
Data Transferred (Sent/Received) [MB/GB]: 435,54 / 1,99
Output Power (Up/Down) [dBm]: 12,8 / 0,0
Line Attenuation (Up/Down) [dB]: 29,1 / 52,5
SN Margin (Up/Down) [dB]: 6,1 / 7,5
Error Seconds (Local/Remote): 4.539 / 0
FEC Errors (Up/Down): 816 / 11.482.163
CRC Errors (Up/Down): 18 / 16.393
HEC Errors (Up/Down): 9 / 15.058
Message 3 of 5
(542 Views)
03-10-2014 7:39 PM
More of the same for last 15-20 minutes, lost syncs as well this time and of course DLM is kicking in as its after 6pm.
Message 4 of 5
(542 Views)
06-10-2014 10:02 AM
Hi Gus,
I've pasted your latest connections above for your reference. I note that our faults team have been notified of the situation too, and picking that ticket up shortly.
I believe that we should be able to sort this out with a little bit of tweaking rather than any engineers.
Tony
Tony
Message 5 of 5
(542 Views)
