gateway checker down ?
- gateway checker down ?
- « Previous
- 1
- 2
- Next »
Re: gateway checker down ?
03-08-2014 1:16 AM
The fix the gateway checker 'could not identify your gateway' problem Plusnet need to change the reverse DNS entry for
link3-central10.pcl-gw01.plus.net (84.93.249.100)
to reflect that it should say pcl-bng02.
David
Message 16 of 21
(433 Views)
03-08-2014 6:48 AM
I think the reverse DNS entries are correct, the problem is that the penultimate hop doesn't respond in the traceroute from the usertools gateway checker to you. This traceroute is in the opposite direction to a traceroute command run on your computer, and many of the hops will have different IP addresses. In Hairy McBiker traceroutes, there weren't the last couple of hops missing, but that's presumably because there were two different length routes mixed together, plus Hairy McBiker's wan IP must respond to pings.
Message 17 of 21
(433 Views)
03-08-2014 10:33 AM
Yes my wan ip responds to pings to allow the BB ping monitor.
Message 18 of 21
(433 Views)
03-08-2014 8:24 PM
just do any outbound traceroute and you find your gateway on first external hop.
Message 19 of 21
(433 Views)
03-08-2014 9:17 PM
Just to add to the responding to pings discussion,
My router is configured to ONLY respond to ping requests from known sources (such as the TBB monitor, HE tunnelbroker, Pingtest, IPv6-test ping test, etc) but silently drops (and logs) all other ping requests.
Running the Plusnet Gateway Checker, does indeed send two ICMP ping requests from 84.92.0.74, two seconds apart.
The gateway checker always gives me the expected Plusnet gateway name, despite those ping requests being silently dropped.
Therefore responding to ICMP pings will give a more complete reverse traceroute, but is not necessary for the Gateway Checker to work.
Message 20 of 21
(433 Views)
19-08-2014 5:43 PM
Quote from: spraxyt To fix the gateway checker 'could not identify your gateway' problem Plusnet need to change the reverse DNS entry for
Plusnet are aware this change is needed and it is in hand under task ref:82558.
Quote from: purleigh Just to add to the responding to pings discussion,
The gateway checker sends one ping to each hop (up to 9) and waits 2 seconds for an answer before stopping or trying the next hop as appropriate. So receiving two pings implies your router is at hop 8. The checker waits two seconds without an answer, so tries to find the destination at hop 9. Obviously that too goes unanswered but as the hop limit is reached the checker stops. However the gateway will have been passed so (if recognised) the answer to the request will be given.
Edit: add final sentence.
David
Message 21 of 21
(433 Views)
- « Previous
- 1
- 2
- Next »
