fubar router
- fubar router
fubar router
09-04-2013 10:03 PM
obviously I need to contact CS and most likely have a new router but is there anything obvious you guys can suggest, I've done the things obvious to me like restart, reset, re-enter details, use different laptop's/desktops all to no avail.
Re: fubar router
09-04-2013 10:27 PM
To do this,
go to your web browser and click here
Enter Admin and the password is the serial number begins with CP (Can be found on the plastic card or underneath router)
Clcik DSL then beside it, it says disconnect, click that,
wait 30 secs
then hit connect.
You should use the gateway checker here Before you follow steps. Make a note of the gateway. Then after you follow steps to see if it has changed.
Check your speeds and it should work.
OTHER USERS - The OP has stated that he receives a 65mbit connection, so don't say speeds fluctuate in first 10 days. Thank you
Re: fubar router
09-04-2013 10:32 PM
Unless your reference to reset was a hard one (sticking a paperclip in the hole) and then fubar about wraps it up
Re: fubar router
09-04-2013 10:37 PM
Re: fubar router
09-04-2013 10:42 PM
Re: fubar router
09-04-2013 10:49 PM
York.
Re: fubar router
09-04-2013 11:00 PM
Re: fubar router
10-04-2013 10:35 AM
Adam
Re: fubar router
10-04-2013 6:03 PM
Re: fubar router
10-04-2013 6:29 PM
Don't get wrong I hope it works fine until I replace the router for better item(dual band WiFi etc)!
Re: fubar router
11-04-2013 9:29 AM
@JamieDanjoux - You really need to watch Tango and Cash One of the greatest action films to come out of the 80s, Kurt Russell and Sly Stallone and a cocaine baron (oh and some dude with the biggest jaw I've ever seen). It's the first time I heard the phrase fubar.
Re: fubar router
11-04-2013 10:00 AM
It's normally shown on one of the ITV channels at least once or twice a year.
Re: fubar router
11-04-2013 11:42 AM
Quote from: Matt It's the first time I heard the phrase fubar.
I think the first time I really noticed it was in "Saving Private Ryan" Lots of use there
