turn on suggestions
fttc question
- fttc question
fttc question
fttc question
06-06-2012 4:43 PM
Can anyone give me a bit of advice. My exchange has just been upgraded to fttc and when I check my number for the speed I can expect it tells me 11.2mb. At the moment I'm getting 8.9mb on ADSL2+. It also tells me on another BT site that I can expect an uplift of 3.52 which should give me about 27mb. Any idea of what I should really get has if I'm only going up 2.2mb I can't see the point of upgrading to fibre.
Re: fttc question
Re: fttc question
06-06-2012 4:47 PM
Can you work out the distance to your cab
Re: fttc question
Re: fttc question
06-06-2012 6:58 PM
Not really has the cabinet is on a main road and we live in an estate and the cable could run in several directions. But has I've said I get 8.9mb now so I reckon its knocked approx 1 mile off the cabinet to the exchange cable so my thinking is, I should get better than the BT estimate of 11.2mb.
Re: fttc question
Re: fttc question
06-06-2012 7:14 PM
Fibre works differently but the BT figure is notoriously conservative
This link gives the basic information http://www.thinkbroadband.com/guide/fibre-broadband.html
