fttc Install fail
- fttc Install fail
fttc Install fail
03-04-2014 10:18 PM
Re: fttc Install fail
03-04-2014 11:09 PM
York.
04-04-2014 10:26 AM
Sorry to see you're not connected at the minute, I've taken a look at your line and it shows that your modem is currently connected.
Is the new router we sent you connected up? If it is then I'd suggest logging into the router and checking the credentials - http://www.plus.net/support/customer_service/using/settings.shtml
Keep me posted on how you get on.
04-04-2014 11:42 AM
04-04-2014 1:50 PM
15-04-2014 8:08 PM
16-04-2014 10:16 AM
I've had a look at your line and it does show you've had a connection;
<img src="http://community.plus.net/visualradius/generated/image13976386002580.png"/>
Looking at your fault I can see there has been an issue with it getting progressed so we haven't been able to get the latest update.
When did the engineer attend?
16-04-2014 2:42 PM
16-04-2014 2:45 PM
16-04-2014 4:30 PM
16-04-2014 5:00 PM
The Head End is referred to in BT Documentation here:
Quote The originating point in a communications system. In TV delivery, the head end is where the programming originates in the network
This was taken from https://www.btplc.com/Sharesandperformance/Presentations/downloads/Network_Teach-in_Mar2013.pdf
In the meantime, I'm investigating what's going on, what's happening and when the issue will be fixed.
17-04-2014 2:06 PM
17-04-2014 3:28 PM
