from a 5.5mb line to a 4mb line why help please
bridtown
hi there when i was changed to max dsl i was on a 5.5mb - 6mb line and i was happy for months and months about 5months
and about 4months ago my line changed to a 4mb line checked through b.t line checker and it says 4mb line a.o.l and the same
can any 1 help me please
thanks
Hustler85
Re: from a 5.5mb line to a 4mb line why help please
Anything change at your end in this time ?
Extra phone, new extension, new router with the product change, different computer running the speed test ?
Tried switching microfilters or connecting to master/test socket and recording your speeds ?
bridtown
yep i have tryed everthing you have said
i have gone wireless since but speed and line went ages before i changed computers.. even force 9 or plusnet says i sould be on a 3-4mb line
James
You are currently syncing with the exchange at 5824Kbps.  If you maintain this speed, then you will be assigned a BT Profile of 5Mbps.  You're currently on 4.5Mbps.
The most important thing here is not what results you're getting on speedtests, but the actually synchronisation speeds that your router is gaining with the exchange.
Please feel free to have a read of the speed troubleshooting guide I wrote, it's linked in my signature.
Hi James,
Where can the actual sync speed be found?
artmo
James
It'll be on your router somewhere Smiley
It's also reported in the BT Speedtest.
OK think I've got it.
On the router it shows line rate 7616 downstream and 448 upload.
I am getting a download speed of about 5Mb.  Is this about right for my line rate?
James
Hey,
It's not far off it.  After you've taken exchange contention into play that's a pretty decent throughput speed.
You're being profiled accordingly for that kind of sync speed, so all is looking pretty decent Smiley
Thanks for your reply.  Two more questions please.  On the BT tester it shows the same figures that I got from my router but it also mentions IP profile of 6500.  How does this fit into the equation?
Also when I use the dslzoneuk.net tester it gives my sync as 8128.  Any reason for the difference?
Finally, a third question.  Is there an FAQ on all these various figures that we're talking about?
Fixes: 167
Your sync speed determines the IP profile, have a look at the link below for more information.
IP Profile
James' blog post should be able to answer you other questions
Speed Queries
 Chris Parr
 Plusnet Staff
Thanks James and Chris for your answers.
Regards,
artmo
