frequent disconnects since phone line fixed
- frequent disconnects since phone line fixed
29-08-2014 2:06 PM
We had DSL problems last week resulting in a BTO engineer visit lastTuesday. He replaced the sockets where the line comes into the house, and problem seemed to be fixed. Siince then we have had v fast speeds but still with intermittent disconnects. Router stats today:
Basic Status
System Up Time:4 day(s) 15:48:38
DSL
Line Status:Connected
DSL Modulation Type:ADSL_2plus
Annex Type:Annex A/L
Upstream Downstream
Current Rate (Kbps) 440 18724
Max Rate (Kbps) 888 18556
SNR Margin (dB) 25.5 2.7
Line Attenuation (dB) 8.5 21.9
Errors (Pkts) 0 0
Should the downstream SNR Margin be so low? Any advice from those who understand these things on what might help? I would happily trade some speed for a more stable connection. (I have reported continuing connection problems on the Plusnet site but no response yet..)
Basic Status
DSL
Upstream Downstream
Errors (Pkts) 0 0
Message 1 of 2
(425 Views)
1 REPLY 1
Re: frequent disconnects since phone line fixed
29-08-2014 3:13 PM
Hey judithps12,
The SNR does look abit low and if you are seeing disconnections, I would recommend we increase this slightly.
I've arranged for this to be done and set the SNR at 6db which I believe will keep the line stable. If you can give it a few hours and then keep an eye on things over the next few days that would be great.
Let me know how you get on.
Dan
Dan
Message 2 of 2
(270 Views)
