firewall ,comodo versus z/alarm???
- firewall ,comodo versus z/alarm???
07-06-2008 6:05 PM
Hi everyone,i know its personal preference but ive been using z/alarm and i noticed someone mentioned comodo.Anybody got any thoughts on which is best and did i read correctly,i got the impression you hardly need an anti virus when using comodo,is that correct.Im giving it a try and im not sure which is best to be honest.
kind regards ray.
Re: firewall ,comodo versus z/alarm???
07-06-2008 6:33 PM
Having said all that, I would say for you to give it a try, but I don't think a firewall could be a substitute for an antivirus program.
07-06-2008 6:47 PM
Thanks for the thoughts mate,i think i prefer the zone alarm for ease of use,i havent had the comodo on that long but i have got avg free +avg antispyware paid for on my machine.I think i may go back to what i know best and i think also that zonealarm is simpler to use.
thanks for the thoughts,ray.
07-06-2008 7:03 PM
Just a note - the free version of ZoneAlarm is missing some of the advanced protection you get with the paid version.
07-06-2008 7:27 PM
Thanks for that oldjim,i think i will just keep with the z/a for now.With the avg/antivirus free+avg paid for antispyware,i think i have all that i need for now but am greatful for your comments.
take care,ray.
07-06-2008 8:23 PM
Btw, sometimes it takes a bit of time getting used to new software, sometimes it's worth perservering with and sometimes not.
07-06-2008 9:06 PM
ZA is very limited unless but a bit lighter on resources ideal for gaming but if you upgrade to pro the app bulks out to about the same level as Comodo.
07-06-2008 9:45 PM
regards ray
08-06-2008 10:51 AM
Can anyone tell me,if i did swap back to comodo,would i need my (avg antispyware paid for version) or not.I have (avg free antivirus),which ive been told,is definetly a nono to get rid of but not sure what i need or dont.Dont like getting rid of paid versions but if theres no need for it and its messing the comodo up with no benifits at all,then i would get rid of whatever is neccessary,if there was definetly benifits over the (free z/alarm)im running now.
regards ray.
08-06-2008 12:39 PM
Regarding using either Comodo or Z/alarm, I wouldn't recommend one over the other, but both have a popular following. Again, it's personal choice.
08-06-2008 12:51 PM
Thanks deiselglider.ray
09-06-2008 9:30 AM
regards ray.
03-08-2008 8:23 PM
I've run Zone Alarm and Comodo and as a couple of posters have already said it's a personal thing - don't think there's a great deal between them.
I found ZA was bringing up blue screens on my XP PRO MCE - maybe it didn't like MCE - who knows...
In any event I changed to Comodo and I have it on four computers and it runs perfectly. I did update to the latest version which I couldn't get on with - and uninstalled it and managed to find a copy of the older version which I reinstalled - now all is fine...
The version of Comodo to get is:- 2.4.18.184
Oh and if you uninstall ZA - make sure it's turned OFF first - if you uninstall it while it's running you may have problems if you need to reinstall it later - it's all well documented on the 'net.
Good luck with which ever one you install and use,
05-08-2008 12:53 PM
In that respect Comodo is the one to have, if you set it to safe mode then you should only get pop ups when you install new programs, when doing that Comodo will ask you if you want to change to installation mode, in which case you won't get any pops up while installing.
06-08-2008 12:43 PM
