fibre stats
stevie66
fibre stats
hi all just had fibre fitted 1 day ago did a speed test and it shows 25 to 30 MB download and 6 to 10 upload now my profie says i should get 76 download and 20 upload is it because i have been active only 1day plus were are the fibre syc stats on my techicolor 582n router
25 REPLIES 25
AndyH
Re: fibre stats
Try going here http://speedtest.btwholesale.com/
Run the speed test, then click on Further Diagnostics and post the results here.
Bright
Re: fibre stats
What time of day did you rune the test? There have been some throughput problems on Plusnet's network during evening peak hours. But at 03.30am you shouldn't be seing those!
Quote from: stevie66
They're in the BTOR modem, not in the router. And assuming it's an ECI model (on the label underneath) they are inaccessible currently.
Bald_Eagle1
Re: fibre stats
Quote from: Bright
But, if it's a Huawei HG612 modem, it can be very easily unlocked:-
http://huaweihg612hacking.wordpress.com/
& the stats harvested/graphed using HG612 Modem Stats 1.0 programs:-
http://www.freewarefiles.com/HG612-Modem-Stats_program_84567.html
chrispurvey
Re: fibre stats
Hi stevie66,
Welcome to our community forums Smiley
I've checked over your line and account and everything currently seems fine, are you currently connecting wired or wireless?
Chris
stevie66
Re: fibre stats
its been 15 days now and my speed is not what its supposed to be done all the bt wholesale test with the combined modem router and with the bt modem and it shows 5 11 25 30 downloads and 5 6 10 uploads now i know i should get more than that the box is outside my apartment and the engineer said i had 80 meg to the box please can you sort it
adamwalker
Fixes: 221
Re: fibre stats
I'm sorry to hear that's still an issue. We'd just need you to raise a fault to get that looked into. That can be done over the phone or directly if you go to http://faults.plus.net
 Adam Walker
leader
Re: fibre stats
Quote from: Bald_Eagle1
Another option is to get an unlocked eci or HG612 off ebay.*
The ECI "I" has the web interface and it the most user friendly.
The "r" is telnet only and has a tendency to lock out the telnet  which means another unlock (solder/uart ) is needed.
However  both unlocked revisions I & r  can be used with 3rd party software such as eDMT.
Anecdotal reports say its best to pair ECI modem with an ECI green box (msan) on the street.( Like wise Huawei to Huawei.)
With a spare unlocked ECI or HG612  any potential  faults/issues can be quickly flagged up.
Cheers
* ( If you not keen on soldering, playing with uarts or flashing firmware ect)
chrispurvey
Re: fibre stats
Hi stevie66,
I've updated your ticket and we've got an appointment booked in for you tomorrow between 8am-1pm.
I've updated your ticket too, let me know how it goes.
stevie66
Re: fibre stats
Quote from: chrispurvey
Hi stevie66,
Chris
65.png>[/URL]
leader
Re: fibre stats
Noticed the prices have dropped as there seems a few more listed over easter weekend.
leader
Re: fibre stats
Just seen that new 35M firmware for the HG612
Looks very promising with higher attainable sync rates
Plus it looks like it works with  Bald_Eagle's Modem Stats 1.0  Cool
Bald_Eagle1
Re: fibre stats
Quote from: leader
It does indeed work.
I have been testing it for a few days now.
It does seem to deliver SLIGHTLY higher sync speed on my poor connection.
Original firmware:-
Path: 0, Upstream rate = 5701 Kbps, Downstream rate = 26007 Kbps
New firmware:-
Path: 0, Upstream rate = 5792 Kbps, Downstream rate = 26712 Kbps
However, it does move bitloading to different tones & misses out quite a lot of the 'Shared/Other' tones (see attached).
leader
Re: fibre stats
Thanks Bald_Eagle.
There seems to be more reports of significant increasing in sync  (close to 10%)
Might have a look on ebay for a spare.*
Makes sense to have one with the new 35M firmware to directly compare.
*(Don't be tempted to mess with the  unit BT installed)
leader
Re: fibre stats
The New 35M Firmware  for  the unlocked HG612,  apparently can only upgraded by the long reset method and not via the gui.
Might have to wait till some cheaper models appear on the aforementioned  auction site.
That way its not such an issue if something goes wrong trying to update & the hg612 becomes a nice door stop for the summer.
