fibre speed question
- Re: fibre speed question
02-02-2014 11:07 AM
phones plusnet i was told
63 download
20 upload
no matter what speed test i do it isnt more than
46 download
12 upload
is this going to increase more or is this what i can expect
02-02-2014 12:09 PM
Are the speed tests you're running being completed with an Ethernet Cable or via Wireless?
If done on Wireless, could you test via Ethernet Connection so we can see if there is much of a difference?
02-02-2014 12:33 PM
02-02-2014 12:46 PM
02-02-2014 12:51 PM
02-02-2014 12:56 PM
02-02-2014 1:06 PM
02-02-2014 1:26 PM
our phone line is only 4 year old as it was installed when we moved as the house didn't have a phone line
for the speeds your offering i could have had a better deal upgrading with SKY we are not happy at all and we paid are fee to sign up and we are not getting what we were told and if this is the case we will be cancelling because your not offering what we were told
02-02-2014 3:16 PM
02-02-2014 3:44 PM
i have now ordered BT infinity because im not messing about it wasn't as advertised.
02-02-2014 4:36 PM
02-02-2014 4:38 PM
The line speed will be the same on all the isp's Have a read of bt retails forum -you soon see a common theme https://community.bt.com/t5/BT-Infinity-Speed-Connection/bd-p/BTInfinity )
What does BT wholesale say on -speed range B FTTC impacted speed ? click the blue link at the bottom and enter line number--
https://www.btwholesale.com/pages/static/Community/Broadband_Community/Coverage/ADSL_Availibility_Ch...
02-02-2014 4:50 PM
For an example, your neighbours may have some electrical gadget which gives out a huge amount of interference which is picked up by your line as "noise" and your speeds will be reduced. Is this predictable - no.
2. That said, it may be that you have genuine fault on the line causing the speed to be reduced to 48, or they may have been some transient problem/interference on the line causing the DLM to reduce the speeds and apply a cap - and it has not increased them/released the cap.
If your line is indeed totally fault free and yet truly not capable of sustaining more that 48 for whatever reason (interference etc) then swapping ISP's to another that uses BT's network will achieve nothing as it is the same physical line from your house back to the cabinet.
Performing a line reset in this case is also pointless as the DLM will just sense the line quality, not like it and merely set it back again to 48.
I expect Plusnet staff will want you to through the faults checker to establish whether there is a fault on the line..........
02-02-2014 6:23 PM
have attached the screen shot of the link Leonardo sent
02-02-2014 6:37 PM
