fibre speed and sync speed
- fibre speed and sync speed
19-02-2014 8:56 PM
My previous adsl sync speed was 10 down and 1.4 up, and i could download at 1mb a sec. my fttc sync speed is unknown as there is no way to find this out but i am only getting 7.5 down and 1 up on speedtest.net.
logged onto plusnet member centre and it says my current line speed is 37.
whats happening here?
thanks
Re: fibre speed and sync speed
19-02-2014 9:24 PM
A DigiCare forum staff will do this for you, when they see this thread. Or if you prefer you can call up.
Also related to the question, don't expect your sync speed to match up with your line speed as the line speed is the profile max.
If you can, please run the speedtest on http://speedtest.btwholesale.com/
- then click further diagnostics after the initial test
- enter your home phone number that FTTC is provided on
It will show your line profile
(like attached)
If yours is the fibre speed, then you should open a fault for slow speed, otherwise if it is ADSL speed as the max achievable speed, then wait and it will be updated
NorthEasterner
19-02-2014 9:26 PM
Quote from: davidfriedlander logged onto plusnet member centre and it says my current line speed is 37.
says this
Quote from: NorthEasterner Plusnet will probably need to update your line profile to the fibre profile.
doesn't need doing, but it would be useful to post the result of the BT speed test.
20-02-2014 9:35 AM
1. Best Effort Test: -provides background information.
Download Speed
7.36 Mbps
0 Mbps 7.51 Mbps
Max Achievable Speed
Download speedachieved during the test was - 7.36 Mbps
For your connection, the acceptable range of speedsis 5.26 Mbps-7.51 Mbps .
Additional Information:
IP Profile for your line is - 7.51 Mbps
Upload Speed
1.01 Mbps
0 Mbps 10 Mbps
Upload speed achieved during the test was - 1.01Mbps
Upstream Rate IP profile on your line is - 10 Mbps
here is from plusnet member centre:
Phone exchange:
BOWMANSGREEN
Estimated line speed:
1.5Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2014-02-19 21:06:20
Current line speed:
37 Mb
something is not right me thinks...
20-02-2014 9:49 AM
I'm really sorry to hear of the issues you're experiencing. I've run a couple of tests on your line and can see a potential issue on your line I'm afraid.
Could you please raise a fault ticket with us so we can get this sorted out for you?
You can do this online at http://faults.plus.net
20-02-2014 9:55 AM
any idea what the potential problem is?
20-02-2014 9:59 AM
I'm unsure as to the quality of the installation, but we'd need to get this looked at.
20-02-2014 10:08 AM
it does actually work and seems stable but not experiencing fibre speeds at all, in fact adsl was much better!
20-02-2014 10:26 AM
Our Faults Team will pick the ticket up within 48-72 hours and we'll make arrangements with you to get that sorted out.
20-02-2014 10:56 AM
20-02-2014 11:04 AM
BT messed up my connection by switching my line to someone else's...
resulting I got their calls and they got mine, and worse that the other person was an elderly couple and didn't have broadband so no broadband came through.
20-02-2014 11:08 AM
20-02-2014 3:28 PM
20-02-2014 3:51 PM
The engineer has shifted your connection into a different port at the cabinet to rule that out as being part of a potential fault The engineer believes that the speeds that you're receiving are likely the best you're going to get on FTTC.
20-02-2014 3:56 PM
do i just need to request my mac key? or is there another process as it is going from fttc to adsl?
