fibre cabinet location
highlander317
Is there any way to find where the cabinet is I am connected to for fibre, well in 2 weeks time.
I know its cabinet 2 and post code is CO153SU, both cabinets at either end of the road do not have numbers on and the one opposite, not a fibre , just has c139 on it. I've been given the estimate speed of 54Mb, just be interested to see where the cabinet was for it.
Cheers in advance
Lee
10 REPLIES 10
Oldjim
Resting Legend
Fixes: 63
Re: fibre cabinet location
Unfortunately no
I asked the staff experts here as I couldn't find mine and the answer basically that the only information they have access to are the post codes fed from a cab
SpendLessTime
Fixes: 86
Lee
You may have more luck asking this on http://www.thinkbroadband.com/
avatastic
I think C139 is a street light controller (if it's the one I found whipping down the road on street view).
I suspect it'll be one of the ones at the end of the road, chances are they've not yet got round to stenciling the numbers on them yet, which they do up to 6ish week (i think) before getting ready to deploy the fibre ones.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
pjmarsh
Fixes: 20
Mine hasn't got a number stencilled on it and I've had fibre for 3 or 4 months now, so that may never happen!
Phil
avatastic
Fair enough  Smiley
I also see, further down the road, that quite a few houses are served by poles so you may find the cab is actually outside the exchange.
I did have a direct to exchange line, but they dropped a traditional cab outside the exchange, moved a bunch of connections to it (including mine) and then put in the fibre cab next to it.
highlander317
computerman142 from thinkbroadband forums sent me this
Cabinet 2 http://goo.gl/eAYgCo
Never even saw this one
Cheers george
chenks76
All Star
Fixes: 12
that's not a fibre cabinet though from the looks of it.
that's the standard PCP cab.
highlander317
There is another almost opposite by phone box and advertising boards
chenks76
All Star
Fixes: 12
that looks more like a fibre cab, albeit a very small one.
avatastic
However that is the same size as the fibre cabinet that I'm currently connected to.
