fibre cabinet location
- Re: fibre cabinet location
28-08-2014 9:04 PM
I know its cabinet 2 and post code is CO153SU, both cabinets at either end of the road do not have numbers on and the one opposite, not a fibre , just has c139 on it. I've been given the estimate speed of 54Mb, just be interested to see where the cabinet was for it.
Cheers in advance
Lee
28-08-2014 9:27 PM
I asked the staff experts here as I couldn't find mine and the answer basically that the only information they have access to are the post codes fed from a cab
28-08-2014 9:41 PM
You may have more luck asking this on http://www.thinkbroadband.com/
28-08-2014 10:33 PM
I suspect it'll be one of the ones at the end of the road, chances are they've not yet got round to stenciling the numbers on them yet, which they do up to 6ish week (i think) before getting ready to deploy the fibre ones.
28-08-2014 10:41 PM
Phil
28-08-2014 10:48 PM
I also see, further down the road, that quite a few houses are served by poles so you may find the cab is actually outside the exchange.
I did have a direct to exchange line, but they dropped a traditional cab outside the exchange, moved a bunch of connections to it (including mine) and then put in the fibre cab next to it.
29-08-2014 8:24 AM
Cabinet 2 http://goo.gl/eAYgCo
Never even saw this one
Cheers george
29-08-2014 8:27 AM
that's the standard PCP cab.
29-08-2014 8:46 AM
29-08-2014 9:20 AM
29-08-2014 9:30 AM
