few more days...
logindukas82
few more days...
Cheesy just to be sure,are there is everithing confirmed for 30.12.13 for my fiber broadband instalation?I hope PN staff can check this for me?
Fixes: 203
Re: few more days...
Hi there
I've checked on our suppliers systems and the appointment is showing for the 30th between 8am and 1pm
Any further issues please give us a shout
 Matthew Wheeler
logindukas82
thanks for your answer.i hope everithing gona be allright....also for fiber BB what speed i gona start whit?my estimate is 79Mbps.....
Plusnet Staff
Plusnet Staff
Fixes: 5
Generally the FTTC speeds are determined within the first 2-3 days of the connection going live.
We'd hope your speeds will be around your speed estimate but we won't know until after the installation as taken place.
Chris Pettitt
Cloud Environments Engineer
logindukas82
good morning all  Smiley are there is any updates on my account? i get email this morning that my line is active to get FTTC and line set to 78 Mbps  Cheesy whits is good start,just still waiting for enginerr to come and do they job....time slot is 8AM to 1PM.....hope they not miss a appointment  Roll eyes
ScottJames
Good luck logindukas82. Hope it all goes to plan for you!
logindukas82
so far,so good,enginerr arrive,do a job on street cab,but line comes whit earth foult,hope change a pairs on cab will helps.....
logindukas82
job done,now have a question,the my account shows the estimate speed is set to 78Mbps,but on speedtest i get arround 36Mbps-45Mbps.....why is that differens?everithing is conected by wires...
Fixes: 162
We've not yet received a line report due to how recently your service was installed, so I can't see whether it's running at a good speed for the line or not. We'll have to check this again tomorrow to see whether a line report has been generated.
 Chris Parr
 Plusnet Staff
logindukas82
i know you told that 2morow you can check when is comes back from OP,just asking if its any news yet ?
Fixes: 162
Your profile is set at 77400 which is really good, so you should be seeing very good speeds now.
 Chris Parr
 Plusnet Staff
logindukas82
thanks for your reply,yes i see that profile is set to 77400kbps,but its strange couse i still get speed arround 35Mbps,and everithing conected by wires....can you give some advice to me?can you check my stats on your side?
We're seeing the same 77400 profile on our supplier's systems now, hoping speeds have improved for you?
logindukas82
no there is no improvement at all....the speed realy get wors.... Sad
Can you paste the results of a BT speed test in here please?
http://speedtest.btwholesale.com
