fastpath FEC Errors
SoFarSoGood
Fixes: 5
fastpath FEC Errors
Hi all
I had interleaving turned off over 12 months ago and iirc FEC errors were 'shown' as 0/0.
It is now showing as FEC Errors (Up/Down): 0 / 9.995.392.
Is this correct, as I thought Forward Error Correction was off when set to Fastpath?
17 REPLIES 17
Anotherone
Champion
Fixes: 21
Re: fastpath FEC Errors
That looks like a bug. Could be caused by anything, maybe a spike of local interference for some reason. You could try a graceful Disconnect - ie log into the modem/router, click Disconnect to drop the PPP Internet session, wait about 30sec/1min then power down for about 10 minutes.
This will reset all the stats and give a graceful resync which won't be interpreted by DLM as a dropped connection. If you are on a long line with low speeds it'll probably be best to do this in daylight hours anytime around now to an hour before sunset should be OK.
Chris
Legend
Fixes: 169
If interleaving is off then you normally won't see any FEC errors showing. It's likely to be as Anotherone describes, something causing a blip in your router stats.
SoFarSoGood
Fixes: 5
Thank you Anotherone and Chris for your help.
I'll give what Anotherone suggests a go and see what happens.
npr
Fixes: 9
Looks to me as though interleaving has been turn on again.
Can you post the full routers stats, that should prove things.
Chris
Legend
Fixes: 169
Interleaving is set to Auto and run mode is showing as Fast, so interleaving shouldn't be on. It'd be interesting if the full stats show anything different.
SoFarSoGood
Fixes: 5
Thanks for your help npr, Chris and Anotherone
BEFORE Disconnect
DSL Connection
Link Information
Uptime: 7 days, 3:11:26
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1.244 / 21.608
Data Transferred (Sent/Received) [GB/MB]: 1,99 / 116,11
Output Power (Up/Down) [dBm]: 12,4 / 0,0
Line Attenuation (Up/Down) [dB]: 7,5 / 15,5
SN Margin (Up/Down) [dB]: 5,9 / 2,6
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 94.981 / 17
FEC Errors (Up/Down): 0 / 11.894.882
CRC Errors (Up/Down): 174 / 1.959
HEC Errors (Up/Down): 674 / 47.172
AFTER Reconnection
DSL Connection
Link Information
Uptime: 0 days, 0:00:50
Bandwidth (Up/Down) [kbps/kbps]: 1.248 / 21.205
Data Transferred (Sent/Received) [kB/kB]: 7,40 / 6,00
Output Power (Up/Down) [dBm]: 12,8 / 0,0
Line Attenuation (Up/Down) [dB]: 7,4 / 15,5
SN Margin (Up/Down) [dB]: 5,8 / 3,7
FEC Errors (Up/Down): 0 / 1.049
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Anotherone
Champion
Fixes: 21
Well to me, that certainly looks as though DS Interleaving has turned on again, which actually comes as no surprise as Chris mentioned it was set on Auto.  Whereas if you requested it be turned off 12months ago, it should not be on Auto at all. Perhaps someone from CRT can place the appropriate Modify order and remembering uncapped upstream as well Wink
Chris
Legend
Fixes: 169
That's telling me that interleaving is on still, even though the DLM data I checked showed the runtime as Fast. I'll place an order to remove this completely and it should complete tomorrow.
Chris
Legend
Fixes: 169
Order placed, they normally complete overnight so hopefully by this time tomorrow it'll be off the line completely.
SoFarSoGood
Fixes: 5
Hi Anotherone and Chris.
Chris, thanks for placing the order
Your help (and Anotherone's) is much appreciated.
Chris
Legend
Fixes: 169
No problem, if you can post some line stats again tomorrow once the order has completed that'd be good so we can see that it's definitely off.
SoFarSoGood
Fixes: 5
Hi Chris
Posting line stats as requested.
DSL Connection
Link Information
Uptime: 0 days, 9:06:54
Bandwidth (Up/Down) [kbps/kbps]: 1.219 / 22.019
Data Transferred (Sent/Received) [MB/MB]: 35,68 / 756,74
Line Attenuation (Up/Down) [dB]: 7,4 / 16,0
SN Margin (Up/Down) [dB]: 6,3 / 3,0
Error Seconds (Local/Remote): 165 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 159
HEC Errors (Up/Down): 0 / 965
JayG
Fixes: 6
To the best of my (limited) knowledge, no FEC errors = no interleaving (i.e. Fastpath.)
SoFarSoGood
Fixes: 5
Hi JayG
Agreed (see my initial post)
