failure after failure
plscott
Financial or other transactions? Not good is it?  Please do something, or I`ll have to.
Fixes: 4
Re: failure after failure
We get a lot of failures with Santander, they are always ringing us after the card fails. I just thought it was par for the course these days.
But none the less infuriating when you need to ring them on a 0845... number to sort it out Sad
Fixes: 62
What on earth is this thread about
If it is Santander it should be in Chit Chat
If it is Plusnet billing it should be in Accounts and Billing
Clarification needed as the previous post by the OP was in August 2012
It had me totally flummoxed as well !
Plusnet Staff
Plusnet Staff
Fixes: 5
Hi plscott,
Could you please elaborate on the issue you're experiencing so we can try and help?
Chris Pettitt
Cloud Environments Engineer
