factory reset
bobbyowner
factory reset
hi all
new to this forum,
i did a factory reset on my thomson tg585 v8,
and now the user name and password will not log me in to it Huh
can anyone help?
Fixes: 46
Re: factory reset
Welcome to the forum. Smiley
I assume you are connected to Plusnet, just can't login to the router web interface.
The username for this should be admin (all lower case) and the password CP..., the 11-character serial number of the router which should be on the label underneath. All letters in the password are capitals, and be careful with 0 (zero) and O (letter).
David
bobbyowner
Re: factory reset
hi thanks spraxyt
it worked a treet  Wink
