extension kit
sosen
extension kit
hi. just have got by mail my router. but there is no extension kit which was asked for during ordering process..
is it just normal ethernet cable you can buy cheap anywhere or something special and i need to keep asking for it quickly before engineer come?.. activation date set up on this friday, so in 3 days..
1 REPLY
Fixes: 68
Re: extension kit
To clarify the extension kit is more of an option for the engineer to install for you so don't worry we've not missed sending you something by mistake. All it means is an option to have the data socket up to 30 metres away from the new master socket.
Hope it all goes to plan on the day!
Adam
 Adam Walker
