ethernet doesn't have valid IP
- ethernet doesn't have valid IP
02-06-2019 12:10 PM
Hi
Using powerline to share ethernet to upstairs. Worked fine until yesterday and now unable to get ethernet to connect. Have no valid IP error. Tired restarting pc, resetting router, changed cables, turned off fast start etc etc.
Any ideas?
Re: ethernet doesn't have valid IP
02-06-2019 12:24 PM
Do you have a switch in your configuration? If so reboot it too, and if you've not done it turn off the power line adapters as well. Restart everything from the router or modem (if its separate) backwards.
Modem
Router
Switch
PowerLine A
PowerLine B
PC
03-06-2019 10:40 AM
Hi @mattarmstead, I'm sorry to hear you're having connection issues. Checking over your connection everything is looking spot on to the router and I'd suggest if you haven't already to do as @Anonymous advised in resetting the power line adapters and perhaps unsyncing and re-syncing them tos ee if this resolves the issue you're seeing. Let us know how it goes.
09-06-2019 4:19 PM
@mattarmstead Can we assume that this is now fixed?
