ethernet doesn't have a valid IP configuration
LeoFox1001
I am getting this message on my PC when trying to get on the internet, I've changed no settings or anything, it just happened a few days ago, can anyone help? All other devices work, just the PC.
Thanks.
Browni
Aspiring Hero
Fixes: 45
Re: ethernet doesn't have a valid IP configuration
From a command prompt enter the following commands
ipconfig /release
ipconfig /renew
that ought to do the trick
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
MKSlinky
Seasoned Pro
I had the exact same problem last week. I thought Plusnet had gone down as I Iost my connection completely but then noticed I still had wireless working on my other devices.
I tried resetting my router first because I couldn't remember the command to use with the CMD prompt. Resetting failed to resolve the problem so then I started looking elsewhere. The Network Troubleshooter was no help and only told me what I already knew, ie. "no valid IP Configuration".
I use TP-Link Powerline adaptors to get network connectivity all over my house and unplugging those sometimes resolves these kind of issues but even that didn't work. I left it until the morning and the same problem still existed.
What actually solved it in the end was rather simple, for whatever reason my TP-Link devices had become 'un-paired'. Pairing them again restored my connection.
LeoFox1001
I'm really quite a novice when it comes to computers, how do you pair the TP-link? what is a TP-link? I tried the previous posters suggestion in the command section, didn't work.
Cheers.
LeoFox1001
Sounds like the exact problem I had, Internet had went down and when it come back on, my PC all of a sudden wouldn't connect, all other devices work.
Browni
Aspiring Hero
Fixes: 45
Start->Settings->Network and internet->Network reset will do a full reset of the networking components and will probably require a system restart.
LeoFox1001
Thanks very much, will try it when I get home.
MKSlinky
Seasoned Pro
@LeoFox1001
If you don't know what a TP-Link Powerline Adaptor is you most likely don't have or even need one.
Here's what they look like, for interest only! http://uk.tp-link.com/products/details/cat-18_TL-PA4010-KIT-V1.20.html
LeoFox1001
Tried this but it's still the same sadly. Thank you anyway.
Browni
Aspiring Hero
Fixes: 45
Have you tried restarting the router?
LeoFox1001
Don't think I'd actually tried that, but did it just now and still nothing, it works when I have a wireless dongle in it, but picks up nothing without it. Strange.
Plusnet Staff
Plusnet Staff
Fixes: 117
If you're using Windows 8 or 10, you could try disabling DHCP which usually resolves this sort of problem I've seen. Here's the guide to do this: https://community.plus.net/t5/Broadband/Disabling-Enabling-DHCP-on-Windows-8-10/td-p/1393553
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
