enable dhcp server on router
- enable dhcp server on router
28-02-2013 12:12 PM
i'm trying to connect a samsung smart hub blueray player when i try to do this (wired connection) i get error message that tells me that i have to enable dhcp server on router can anyone help this is my first post
allypm
allypm
Message 1 of 6
(6,928 Views)
5 REPLIES 5
Re: enable dhcp server on router
28-02-2013 12:34 PM
Welcome to the forums.
If you are using the default PN router, the dhcp is enabled by default.
Do you have it (the player) connected to the router by a cable or by wifi?
Message 2 of 6
(5,841 Views)
28-02-2013 12:45 PM
As Hairy Biker just pointed out DHCP is already on if you have a plusnet router.
have a look here and try a manual setup http://downloadcenter.samsung.com/content/UM/201203/20120307144909948/02227S-BD-E5500-XS-ENG-BM-0307...
ip 192.168.1.22
subnet 255.255.255.0
gateway 192.168.1.254
dns 192.168.1.254
ip 192.168.1.22
dns 192.168.1.254
Message 3 of 6
(5,841 Views)
01-03-2013 11:58 AM
dvd has wired connection i have been told (don't know if this is correct) but it is dynamic connection so that ip address changes all the time router is technicolor tg582n plusnet i could be talking rubish hope someone can help me
regards
allypm
regards
allypm
Message 4 of 6
(5,841 Views)
01-03-2013 12:07 PM
In the routers network pages, go to the settings for the dvd and tick "Always use the same IP address"
Is this what you're asking for?
Message 5 of 6
(5,841 Views)
01-03-2013 12:44 PM
I think that the dynamic connection you are referencing is the BB connection, this has now't to do with your internal network.
If you have a wired connection then check the back of the player and you should see a connection with a light on it, with a cable going to the router, if there is no light then you may have a faulty cable, or the connection may be loose.
Check it is pushed fully home, it should "click in" with a small release leaver on the top, also check the other end is fully home.
Message 6 of 6
(5,841 Views)
