email problems...
- email problems...
Re: email problems...
10-07-2008 12:08 PM
Post up your router stats (as I mentioned in the PM) and we'll see what we can do to get it rectified
B.
10-07-2008 12:16 PM
You are currently syncing to the exchange at 128k downstream and 64k upstream, something is definitely wrong.
Make sure you are connected in to the master socket with 1 filter, remove all other telephony devices and then check the sync speed as advised by Barry.
10-07-2008 12:44 PM
Thanks for that.
Just removed the phone completely, I use an Orchid dialler but all that's disconnected for now. All i have connected is the DLink 2640B straight into a filter then straight into the master socket. I've also tried the other filter but same results...
Incidentally I'm using wireless, set the computer up using NetStumbler - the whole thing took literally a couple of minutes and I was up and running, (well crawling!!!)
Presumably this problem is line related?
We've not had problems with the phone for years - appreciate tho' that might not be relevant...
I just ran BroadbandSpeedChecker again (12:40) and speeds reported as:-
download = 96k
upload = 52k
Really appreciate your help,
10-07-2008 12:47 PM
*goes to run another line test*
10-07-2008 12:51 PM
10-07-2008 12:52 PM
Can I do it or must it be done at the 'other end' ?
I've had broadband for years but it was wireless broadband via local ISP straight to my wireless card via an outside antenna - so I've NO experience (or knowledge!) of using landline/routers...
(says he tongue in cheek...)
Thanks,
10-07-2008 12:53 PM
Also, have you tried plugging into the Test socket *behind* the master socket. (unscrew the bottom half of the master faceplate)
Try that, and report back the 'Sync' speed from your router (not a speedtest).
To get your sync speed depends greatly on the router itself. What router are you currently using?
B.
10-07-2008 12:54 PM
10-07-2008 1:11 PM
Tried to report a problem to PN but one of the questions I get asked is "on what date was your service fully working". As it's never worked properly can't really fill that in SO can't go any further...
Ref the SkyBox etc - no - at the moment I've NOTHING but the router and filter connected to the master socket.
Incidentally I can't remove the front of the master socket to plug the filter inside it - it's an older one...
Ref the router sync details - my router is not listed on the drop down menu - it's a D-Link DSL-2640B
Thanks guys,
10-07-2008 1:35 PM
Downloaded from here
Quote Section 4 - Troubleshooting
ADSL STATISTICS
This window displays ADSL information including Link Rate, SNR, and some Error Counters.
10-07-2008 2:00 PM
Quote from: PNnewbie
If I was faced with this situation I would enter a date that was before you were first connected.
10-07-2008 2:07 PM
(presume the manual is on the disc that came with the router - being an old grandad I HATE manuals on disc - much prefer a hard copy - probably not good for the environment tho' !)
Went into the router and these are the figs that might interest you:-
Downstream Upstream Rate (Kbps): 128 64
SNR Margin (dB): 29.8 31.0
Attenuation (dB): 52.0 28.0
That looks bad?
gewhizz - maybe try that - the software looks for a numerical answer so obviously more suited to someone who has had broadband running properly for a while then ran into problems...
Thanks again,
10-07-2008 2:09 PM
Continue to raise a fault using an old date as per the suggestion above. Once you have a fault raised, post back the ticket number here and I'm sure Chris can pick it up.
B.
10-07-2008 2:16 PM
10-07-2008 2:41 PM
Followed your link to do the stats connection check, the 'Broadband fault checker' is running and tells me to come back in a couple of hours...
no mention of a ticket number...
john
