email on ipod touch
- email on ipod touch
email on ipod touch
07-03-2009 4:17 PM
:'(i have try to setup my email on my ipod touch with no luck it starts with imap or pop which one then asks
name
address
description
incoming mail server
host name
user name
password
outgoing server
hose name
user name; optional
password ;optional
if anyone can help me to set this up i will be so o o o happy thanks .
name
address
description
host name
user name
password
outgoing server
hose name
user name; optional
password ;optional
Message 1 of 7
(2,517 Views)
6 REPLIES 6
Re: email on ipod touch
08-03-2009 1:27 AM
I think the settings you need for this should be those given on the Member Centre Connection Details page (here). The Mobile Phone Email Guide might also help.
Please be aware of the following:
I think that almost certainly will be the case since the Plusnet relays will not allow you to send mail unless connected via Plusnet broadband.
Quote Note: For GPRS access, you may need to use your phone provider's outgoing mail server so that you can send email from your phone. Receiving email should be unrestricted.
David
Message 2 of 7
(591 Views)
08-03-2009 7:28 AM
This works for me:
name Your name (e.g. Fred Smith)
address Your e-mail address (e.g. fred@smith.plus.com)
description mail.plus.net
host name mail.plus.net
user name Your PlusNet mailbox name (e.g. smith+fred)
password Your mailbox password
outgoing server
hose name relay.plus.net
user name; optional
password ;optional
We use Outlook Express and if you sync your iPod with iTunes, it will set it all up for you automatically and also download all your contacts.
Bob
outgoing server
user name; optional
password ;optional
Bob
Message 3 of 7
(591 Views)
08-03-2009 10:39 AM
Quote from: spraxyt Note: For GPRS access, you may need to use your phone provider's outgoing mail server so that you can send email from your phone. Receiving email should be unrestricted.
FYI the ipod Touch does not have GPRS it connect to the internet using WiFi only.
The settings specified by @bobboulby are correct but I would recommend filling out the Username and Password for the outgoing server it you intend to use public WiFi points. The Username and Password for the outgoing server have to be your account and not your mailbox ones.
Message 4 of 7
(591 Views)
08-03-2009 12:11 PM
Quote from: bobboulby user name Your PlusNet mailbox name (e.g. fred+smith)
For the example quoted I think that should be smith+fred
and for the outgoing server
user name would be smith
password your main account password
David
Message 5 of 7
(591 Views)
08-03-2009 9:33 PM
Quote from: spraxyt
Oops, corrected in original post.
Bob.
Message 6 of 7
(591 Views)
08-03-2009 9:47 PM
Quote from: itsme I would recommend filling out the Username and Password for the outgoing server it you intend to use public WiFi points. The Username and Password for the outgoing server have to be your account and not your mailbox ones.
So if you enter the username and password for the relay server does that allow you to send e-mail from any wi-fi network?
Bob.
Message 7 of 7
(591 Views)
