dropped connections and slow as a snail!
- Re: dropped connections and slow as a snail!
23-09-2013 12:16 AM
What is happening to Plusnet? Today my broadband connection keeps dropping out every 20 mins or so and when I do manage to reconnect my speed is so slow it's like being on dial up not broadband. What is going on?
Message 1 of 4
(714 Views)
3 REPLIES 3
23-09-2013 8:48 AM
if you haven't done so already i'd run through a fault tester.
the frequent drops will be causing the dlm to reprofile your line into a snail, and it certainly sounds like a fault situation
Message 2 of 4
(398 Views)
23-09-2013 9:01 AM
Have you tried using the test socket inside the master socket?
Message 3 of 4
(398 Views)
23-09-2013 4:28 PM
Hi there, from checking your connection logs it's not pretty:
<img src="http://community.plus.net/visualradius/generated/image13799499734621.png"/>
I'd definitely test the connection with the router in the test socket to see if that helps. If it still drops when that's been set up then you've proved a line fault and should raise it to us at http://faults.plus.net
If it fixes the issue then there's most likely a problem with your internal wiring somewhere, I'm afraid that's not something we'd be able to help with except being able to offer general advice.
Message 4 of 4
(398 Views)
