dropouts a lot over last few days
vfr750
I am getting regular drop outs from my internet connection
Can you do some tests to check it .
quiet line test seems ok.
35 REPLIES 35
vfr750
Re: dropouts a lot over last few days
It seems to be a line fault again.
I have got no dial tone at all now on my landline.
I have just tested at the master socket with an analogue phone.
no connection and at.
internet still works when it is connected, speeds seem okay.
Fixes: 334
Then report a PHONE fault via:https://www.plus.net/help/report-a-problem/phone/
vfr750
Thanks I have done that,
just waiting for tests.
vfr750
Line fault.
Engineer booked for Monday afternoon.
willcutforth
Fixes: 113
I will pop this on hold until Monday and check back with you. Smiley
 Will Cutforth
vfr750
The fault is different today, I have got a phone connection again,
but the internet speed is down a bit, although it seems stable.
We did have snow the other day when the faults seemed to first appear.
it is dry today.
so will wait and see if they can find the fault on Monday.
Fixes: 334
@vfr750 How far down? If the phone fault is repaired, the internet connection should improve. What router are you using?
vfr750
the speeds have dropped from 37 to 30 on download  and  9 to 8 on upload
I have a BT hub 6
I have had similar line faults in the past, always been a bad line,
mostly where it goes through some trees.
Fixes: 334
Thanks. I don't know the BT Hub6, but does it have page showing similar details to the below picture?
vfr750
has something close to those details on the router
Fixes: 334
Can you post a screenshot, obscuring any personal details, please?
vfr750
Fixes: 334
Cheers for that - I assume you are on an 40/10 profile? IF not, something is seriously wrong.
vfr750
yes on 38-10 I think.
I have looked at the wan errors log it seems to be clear from 6am today.wan errors.jpg
