download/upload speeds have dropped - can i change my own SN targets?
- Re: download/upload speeds have dropped - can i ch...
04-02-2010 8:25 AM
hey all,
for many months ive had a cracking (for me) 3.7M download / 0.7 upload with SN of 5 / 9db up down. this has been great and in line with my synch which is:
Bandwidth (Up/Down) [kbps/kbps]: 871 / 4,544
However, recently (last 4 weeks) my SNs have jumped up to 6.5 / 11 and as a result my download has been slashed to 2.2M so i can no longer stream HD content from xbox live video marketplace
with the Thomson gateway router can i manually go in and change the SN targets, otherwise can a plusnet rep do it for me? my connection was rock solid at the lower SNs so cant understand why its changed.
many thanks.
many thanks.
Message 1 of 3
(773 Views)
2 REPLIES 2
Re: download/upload speeds have dropped - can i change my own SN targets?
04-02-2010 9:07 AM
Certainly download SNRs can be changed by the user - I do so on my connection which uses a Belkin router. Don't know about the Thompson, will leave that for others to answer.
Message 2 of 3
(323 Views)
04-02-2010 10:40 AM
The DMT tool can be use to lower SNR I believe.
Message 3 of 3
(323 Views)
