download speed
- download speed
download speed
04-03-2010 1:33 PM
Re: download speed
04-03-2010 1:41 PM
Re: download speed
04-03-2010 1:54 PM
Quote I am on the 8meg package
you forgot the words UP TO
Re: download speed
05-03-2010 12:10 AM
Can you explain how to check the router stats please? Thanks!
Re: download speed
05-03-2010 12:23 AM
Re: download speed
05-03-2010 5:24 PM
FAO: Matt Taylor, here are the router stats:
Uptime: 0 days, 0:09:11
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,600
Output Power (Up/Down) [dBm]: 11.5 / 17.0
Line Attenuation (Up/Down) [dB]: 31.5 / 55.0
SN Margin (Up/Down) [dB]: 18.0 / 15.5
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 25
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Many thanks for your help!
Re: download speed
07-03-2010 2:32 AM
Re: download speed
08-03-2010 7:19 PM
Re: download speed
08-03-2010 8:04 PM
Re: download speed
08-03-2010 9:17 PM
Re: download speed
08-03-2010 11:29 PM
Re: download speed
08-03-2010 11:59 PM
Re: download speed
09-03-2010 12:39 AM
Re: download speed
09-03-2010 1:59 PM
It looks like there might be an intermittent connection present on the line (unless you're powering the router down 5 times a day or so). If the former I'd definitely recommend raising us an intermittent fault at http://faults.plus.net
If it is you powering the router off then on again I'd recommend telling the router to disconnect and then reconnect, as a forced reboot like that looks like a loss of connection to the exchange and may cause a drop in profile.
Re: download speed
09-03-2010 4:00 PM
Hi Matt, I do power the modem on and off several times a day to save wasting power. Are you saying that the exchange sees this as dropouts?
Also I am confused as to what you mean by telling the router to diconnect and then re-connect.
