does support work weekends
- does support work weekends
09-02-2013 2:37 PM
Hi have problems with my broadband and after 3 days finally got a completed order only to find that it can now take another 72 hours to fix a fault with it.
So was wondering if support work weekends or will it be up to 72 hours from Monday
Message 1 of 2
(625 Views)
1 REPLY 1
Re: does support work weekends
11-02-2013 10:06 AM
Our support team do work weekends so the 72 hours is from the point you raised the fault. Have you tried connecting again? When you raised the fault we did actually have a network issue where customers could not connect - <a href="http://usertools.plus.net/status/archive/1360352450.htm">link</a> which is now resolved.
We'll be responding to your ticket today.
Chris
Chris
Message 2 of 2
(353 Views)
