does DLM still work?
- Re: does DLM still work?
16-05-2014 1:16 PM
Waited 4hours before rebooting and no change
Waited a further 12 hours and no change
Waited a further 19 hours till now and no change
Are we back to the bad old days of DLM taking days to work?
16-05-2014 1:58 PM
16-05-2014 2:07 PM
16-05-2014 2:50 PM
Your line has been 'Amber' from the historical data I can see. After the re-sync, your Line Quality has gone 'Green' so you should start to see an improvement shortly.
16-05-2014 3:32 PM
16-05-2014 3:37 PM
If your line errors but not enough to cause your connection to drop, thus keeping it stable, your Line Quality won't go to green to lower your SNR as the lower your SNR is, the more likely you are to get more errors on your line.
For whatever reason, your Line Quality has switched to Green today, so whatever was causing the errors/interference has stopped, which is why DLM is now finding your line more healthy and will reduce your SNR.
16-05-2014 4:40 PM
If you have not already done so, there might be merit in installing and configuring routerstats - http://www.vwlowen.co.uk/internet/files.htm - to monitor your SNRM to determine if you are suffering from external noise.
16-05-2014 5:54 PM
Since January my connection has been the best it ever has and as I stated before the only problem I have has was constant packetloss, which Bob figured out to be faulty BT equipment beyond the gateway.
16-05-2014 6:35 PM
Quote from: Gus back to the bad old days of DLM taking days to work?
I don't think the DLM has ever made positive changes without waiting a few days.
26-05-2014 9:45 AM
So I ask again does DLM still work
26-05-2014 2:38 PM
