do these figure support a SNR
- Re: do these figure support a SNR
22-04-2013 7:28 PM
Can i get a SNR with these figures i believe i should be getting around 1Mbps more i am on a 21CN. my usual is around the 4.6 - 4.7Mbps
1. Best Effort Test: -provides background information.
Download Speed
4.72 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 4.72 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 5.53 Mbps
Upload Speed
0.91 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.91Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
DSP Firmware Version A2pB025f.d22k
DMT Status No Defect
Operational Mode ADSL2+
Upstream 1064
Downstream 6272
SNR Margin(Upstream) 5.8
SNR Margin(Downstream) 5.3
Line Attenuation(Upstream) 32.8
Line Attenuation(Downstream) 53.5
Estimated line speed:
Current line speed:
5 Mb
Sorry if this is wrong but every little helps
Robert
Download Speed
4.72 Mbps
0 Mbps 7.15 Mbps
Upload Speed
0.91 Mbps
0 Mbps 0.83 Mbps
Upstream 1064
Downstream 6272
Current line speed:
5 Mb
Robert
Message 1 of 4
(1,171 Views)
3 REPLIES 3
22-04-2013 7:55 PM
Quote from: crobertbailey ...
Current line speed:
5 Mb
You don't need a SNR reset, you need the Plusnet current line speed updated to match the BT profile.
Message 2 of 4
(385 Views)
23-04-2013 10:19 AM
Message 3 of 4
(385 Views)
23-04-2013 12:18 PM
Thanks all for the help with this, i don't really know enough about this but just thought i would ask as i thought my actual speed should be something like 82% of my downstream speed which is usually around the 6300 mark.
Robert
Robert
Message 4 of 4
(385 Views)
