dlm reset/gea test
Lwood1994
dlm reset/gea test
hello. my broadband speed seems to be in a constand downward trend and now is again under my mininum garanteed speed.
When I moved to this property 7 years ago, i was getting 75/20, but now I'm struggling to get 40/15. Can this be looked into, please
6 REPLIES 6
Fixes: 251
Re: dlm reset/gea test
Are those sync speeds or data test speeds?
Can you share the router stats please?
Lwood1994
These are speed test.net speeds. I’ve been getting random dropouts also.
Lwood1994
At the moment I’ve got
Profile:17a
Up speed:16994Kbps
Down speed:43999Kbps
Snr up 9db
Snr down 12db
Fixes: 251
That looks like a banded DS speed.   US looks as though it might do a bit better too.  Probably worth running the faults bot.  See the link.below.
Lwood1994
ive put in a request. can i get the gea test and a dlm reset
Fixes: 387
You will have to see what the faults bot replies.
