distance to exchange
- distance to exchange
11-07-2008 11:14 AM
A colleague is thinking of getting broadband, and we were discussing the distance from the exchange. I know there's a way to measure it, but I can't remember where. CAn anyone help?
Message 1 of 6
(1,208 Views)
5 REPLIES 5
Re: distance to exchange
11-07-2008 11:15 AM
Hi John, this might be what you are looking for http://www.dslzoneuk.net/distance.php
Message 2 of 6
(446 Views)
11-07-2008 11:19 AM
Thanks Spuggy.
He's also just done a BT speedcheck on the number, and it says his maximum speed is around 0.5 Mb. I know he lives in the wilds of Essex, but that seems very low!
(According to DSL zone, he's 4.53 Km as the crow flies from the exchange.)
Message 3 of 6
(446 Views)
11-07-2008 12:50 PM
Others will know more than me (cue PN bod ) but 0.5Mb would seem about right esp as the real length of the line would me more than 5km and that is definatly a long line!
Message 4 of 6
(446 Views)
11-07-2008 1:08 PM
Line speed is determined by the signal strength and signal to noise ratio on the line. Line length has a big effect, but the quality of the wiring is just as important. 4.5km of new wire would give better speeds than old wires with lots of corroded joints, but 0.5Mb would sound about right. The test websites can only give an estimate of the likely speeds. You can try <a href="http://www.samknows.com/broadband/checker2.php">this one</a> as well.
Message 5 of 6
(446 Views)
11-07-2008 1:34 PM
You might try the Kitz checker here. This gives quite a comprehensive summary including distance by road.
David
Message 6 of 6
(446 Views)
