disconnecting every 1 min
- disconnecting every 1 min
Re: disconnecting every 1 min
18-11-2011 9:46 PM
18-11-2011 9:48 PM
18-11-2011 10:28 PM
If they don't then I think the Digital Care Team can do a manual tweak or at least they used to be able to
18-11-2011 11:27 PM
The absence of PPP session drops is encouraging - the improvement might simply be due to cleaning the contacts when the filters and cables were unplugged and plugged in again.
Upstream sync speeds slightly less than 448kbps are normal on ADSL2+ (even for LLU connections), presumably it's something to do with the technology.
Your upstream sync speed being (notionally) 448kbps whereas caulbox's is 1195kbps is not indicative of a fault. It depends how the service is configured, with capped 448kbps upstream as one option, uncapped the other. I understand fault rates on 21CN were significantly higher with uncapped upstream so bulk upgrades generally start with upstream capped. For stand-alone upgrades I think it is up to the agent, but capped is the default.
Plusnet will change ADSL2+ users to uncapped upstream if requested - this is free of charge. In your case I suggest requesting uncapping, but wait a few days to confirm disconnections really have gone away.
How long have you been on 21CN/ADSL2+?
18-11-2011 11:34 PM
19-11-2011 6:24 PM
20-11-2011 2:08 AM
Quote from: delaneya only problem I have now is stupid windows 7 wont allow me to use a Ethernet cable says its public network. wireless works though. and the cable works on the xbox.
Is this the dual network problem associated with Bonjour?
20-11-2011 7:46 AM
Quote from: spraxyt Is this the dual network problem associated with Bonjour?
I'm lost again in understanding all this so this ISN'T a recommendation. But might SZ PortScan be a useful diagnostic tool in this context?
Just ran the software myself, and (for me) it does link to an option to "install Bonjour to find more devices". Given that (to quote from from spraxyt's link) "<Bonjour> does not play well with windows services as a rule" I'd wait for a more qualified answer from others before choosing that option!
20-11-2011 10:13 AM
23-11-2011 7:13 PM
23-11-2011 7:21 PM
23-11-2011 7:23 PM
23-11-2011 7:32 PM
Unless you get loads of uncorrected errors I wouldn't go for interleaved as you ping will about double
23-11-2011 7:43 PM
23-11-2011 8:13 PM
I assume that you still have a 3dB noise margin - that should probably be raised to 6dB (the automatic systems should do that themselves)
Also your MTU is too low - I have mine set to 1500
