disastrous upload speed but normal download speed.
Soely
Hi all, I'm having a huge problem with upload speed. I basically cannot do anything at all besides surfing web and downloading things like crazy.
I cannot game, I can't do video or even voice calls or else the connection would drop.
I've tried rebooting the modem, changing routersplitter, changing wifi channels and even the test sockets but everything seems the same.
Fixes: 10
Re: disastrous upload speed but normal download speed.
Could you post the information asked for here please: http://community.plus.net/forum/index.php/topic,96155.0.html
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Soely
Link Information
Uptime: 0 days, 17:57:35
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 446 / 4.364
Data Transferred (Sent/Received) [MB/GB]: 927,85 / 1,99
Download speed: 3.34 Mb
Uploadspeed: 0.28 Mb
Estimated line speed:
Current line speed:
3.6 Mb
Fixes: 62
Nothing to obvious there except your upload speed is rather low - in fact very low for the sync
Can you try this speed test http://www.thinkbroadband.com/speedtest.html?utm_source=mainsite&utm_medium=navigation&utm_campaign=... and report the results
Also can you install Networx http://www.softperfect.com/products/networx/ and see if there are any uploads running on your machine
A further thought - do you have any other devices connected to the router
If so can you disconnect them and run the speed test again
You can also ask for the upload to be uncapped which will give you a useful increase in sync speed but this may not solve the underlying cause
Fixes: 10
Could you post the full router stats please as they may give us more information. If you have a Plusnet provided router the information should look like this:
[quote=Example of TG582 router stats]Uptime: 36 days, 11:55:25
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 832 / 8,128
Data Transferred (Sent/Received) [GB/GB]: 4.20 / 28.32
Output Power (Up/Down) [dBm]: 12.3 / 19.9
Line Attenuation (Up/Down) [dB]: 11.0 / 20.0
SN Margin (Up/Down) [dB]: 15.0 / 6.4
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 279 / -
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 183 / 446
HEC Errors (Up/Down): - / 544
Fixes: 10
Also, do you connect to the router wired or wireless? If it's wireless could you run the speed test wired please and post the results.
Soely
thanks peeps. give me a moment i'll try to get everything checked
Soely
DSL Connection
Link Information
Uptime: 0 days, 18:16:16
Data Transferred (Sent/Received) [MB/GB]: 984,87 / 1,99
Output Power (Up/Down) [dBm]: 12,0 / 19,4
Line Attenuation (Up/Down) [dB]: 28,9 / 51,5
SN Margin (Up/Down) [dB]: 18,1 / 9,0
Loss of Framing (Local/Remote): 18 / 0
Loss of Signal (Local/Remote): 2 / 0
Error Seconds (Local/Remote): 12.488 / 0
FEC Errors (Up/Down): 0 / 1.345.126
CRC Errors (Up/Down): 0 / 29.708
HEC Errors (Up/Down): 0 / 352.134
this is the dsl info from the router
Fixes: 10
Thanks - thats confirmed one thing. You need to ask Plusnet to uncap your upload which will give you upload sync. We still need to look at why the actual speed is nowhere near the sync.
Soely
The speedtest that you gave me got stuck at stage 3 stating that they're initiating upload test. it says it takes a few seconds but its been some time  Sad
There's nothing else connected to the router besides my phone which i switched off the wifi but still doesn't help a bit.
i'm installing networx now
Quote from: Oldjim
Fixes: 62
Do you remember how long ago you rebooted the router as the error secs look very high
Soely
http://www.thinkbroadband.com/speedtest/results.html?id=139427455645278374486
this is the results i got from think broadband.
I'm not sure how to get results from networx though..
Quote from: Oldjim
Soely
Quote from: Oldjim
I rebooted it  yesterday afternoon I think. Then I changed the splitter after realizing it didn't help.
and the last time it rebooted was when I use the test port in the main phone line thing.
Fixes: 62
With NetworX right click on the icon and select show graph
This will show if anything else is hogging your upstream bandwidth
That many error secs in that time is indeed high and may be part of the problem
I have 1,544 in 18 days
Soely
Quote from: Oldjim
What can I do to fix that?
I attached the networx graph down there.
