did something happen (on the way to the forum) overnight 12-13 Apr 2022?
graemev
FYI, I checked the broadband status for events in past 24 hour , nothing.
I'm used my Vigor 2860 dropping an restabilising the line , I lose showtime. I always get emailed syslog events (down & up) about a minute apart. This one was odd in that, it was down for an hour but my traces show it maintained SHOWTIME throughout and quite good speeds.
Logs type call:
Time Log Type Message
Apr 12 23:16:04 Call PPP Closed : No Echo Response (PPPoE)
Apr 12 23:16:28 Call PPP Closed : LCP Time-out (PPPoE)
Apr 12 23:16:29 Call >>> Dial-up triggered by user : 192.168.1.151 ; proto=UDP, to 8.8.8.8 port=domain
type wan:
Apr 12 23:16:12 Wan WAN1 PPPoE ==> Protocol:LCP(c021) TermReq Identifier:0x17
Apr 12 23:16:20 Wan WAN1 PPPoE ==> Protocol:LCP(c021) TermReq Identifier:0x18
Apr 12 23:16:28 Wan WAN 1 is down.
Apr 12 23:16:29 Wan WAN1 PPPoE ==> V:1 T:1 PADT ID:5259
Apr 12 23:16:29 Wan WAN1 PPPoE ==> V:1 T:1 PADI ID:0
Apr 12 23:16:35 Wan WAN1 PPPoE ==> V:1 T:1 PADT ID:0
Apr 12 23:16:39 Wan statistic: WAN1: Tx 52 Kbps, Rx 35 Kbps (30 min average)
Apr 12 23:16:39 Wan statistic: WAN2: Tx 0 Kbps, Rx 0 Kbps (30 min average)
Apr 12 23:16:39 Wan statistic: WAN3: Tx 0 Kbps, Rx 0 Kbps (30 min average)
Apr 12 23:16:39 Wan statistic: WAN4: Tx 0 Kbps, Rx 0 Kbps (30 min average)
Apr 12 23:16:39 Wan statistic: Session Usage: 166 (30 min average)
Apr 12 23:16:39 Wan statistic: Session Usage: 483 (5 min average)
Apr 12 23:16:47 Wan WAN1 PPPoE ==> V:1 T:1 PADT ID:0
Apr 12 23:16:59 Wan WAN1 PPPoE ==> V:1 T:1 PADT ID:0
Apr 12 23:17:11 Wan WAN1 PPPoE ==> V:1 T:1 PADT ID:0
Apr 12 23:17:23 Wan WAN1 PPPoE ==> V:1 T:1 PADT ID:0
above repeated a lot, then :
Then later:
Apr 13 00:43:23 Wan WAN1 PPPoE ==> V:1 T:1 PADT ID:0
Apr 13 00:43:35 Wan WAN1 PPPoE ==> V:1 T:1 PADT ID:0
Apr 13 00:43:47 Wan WAN1 PPPoE ==> V:1 T:1 PADT ID:0
Apr 13 00:43:47 Wan WAN1 PPPoE <== V:1 T:1 PADO ID:0
Apr 13 00:43:47 Wan WAN1 PPPoE ==> V:1 T:1 PADR ID:0
Apr 13 00:43:47 Wan WAN1 PPPoE <== V:1 T:1 PADS ID:7205
Apr 13 00:43:47 Call PPP Start (PPPoE)
Apr 13 00:43:47 Wan WAN1 PPPoE ==> Protocol:LCP(c021) ConfReq Identifier:0x00 MRU: 1520
Apr 13 00:43:47 Wan WAN1 PPPoE <== Protocol:LCP(c021) ConfReq Identifier:0x7F MRU: 1500 Authentication Type: CHAP 05 Magic Number: 0x7c366a20
Apr 13 00:43:47 Wan WAN1 PPPoE ==> Protocol:LCP(c021) ConfAck Identifier:0x7F MRU: 1500 Authentication Type: CHAP 05 Magic Number: 0x7c366a20
Apr 13 00:43:47 Wan WAN1 PPPoE <== Protocol:LCP(c021) ConfAck Identifier:0x00 MRU: 1520
Just the call records:
Apr 13 00:43:50 Call CHAP Login OK (PPPoE)
Apr 13 00:43:50 Call IPCP Opening (PPPoE); Own IP Address : xx.xx.xx.xx Peer IP Address : 195.166.130.254; Primary DNS : 212.159.6.9 Secondary DNS : 212.159.6.10
But , as can be seen , SHOWTIME maintained.
My guess would be the DSL is running fine but plusnet shut things down at the IP level...but nothing in plusnet status?
4 REPLIES 4
Mav
Fixes: 518
Re: did something happen (on the way to the forum) overnight 12-13 Apr 2022?
Moderator's note(s):
Thread moved from ADSL Broadband to Fibre Broadband.
Forum Moderator and Customer
SammyM
Fixes: 101
Hiya @graemev
Thanks for getting in touch, I appreciate it.
Looking at it, it's most likely to be maintenance at the exchange occurring Smiley
Please get in touch if you need any further help.
 Sammy M - Sheffield Team
Alex
Fixes: 13
I would give it until this evening, and only raise a fault if things don't improve then.
As @SammyM said, just maintenance and it should have gone within an hour or two.
When I walk past local exchanges I look to see if any vans are outside. 🙂
graemev
It only lasted an hour, outside of that it's been fine.
Just curious error, given the "level" it occurred at ... thought maybe some central kit (Radius etc) gone down
