delete of earlier advertisment in classified .
db100547
how tthe hell does one delete an advertisment of goods wanted/for sale in the classified section ..  The help system is useless and also incorrect .  it says go to the modify section and press the delete button .
but where the HELL  is the delete button ?
db100547 . !!!!!!! ( annoyed as i cant find it ANTWERE!)
pierre_pierre
Re: delete of earlier advertisment in classified .
the only person who can delete (Move to Archive) is the mods, all was removed earlier this year because of an incident
Fixes: 257
your best bet is just to edit the text and replace it with some other text, such as 'not needed now'
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Or at least link to the item asking for it to be removed, or perhaps reply to the item asking for it to be removed.
I guess you are talking about this post? http://community.plus.net/forum/index.php/topic,68195.msg544932.html#new
If you want it removing, just say to and it shall begone! Wink
db100547
Quote from: James_G
Hi James , Actually NO not that one .  It was an earlier one that i was refering to .....  but many thanks for your answer.......
Dave ( db100547)
