del.icio.us inaccessible through PlusNet
psross
Is anyone else finding that http://del.icio.us is inaccessible through PlusNet? I can ping the server, but HTTP requests just time out.
The site is working fine when I connect through other ISPs.
Thanks,
Phil
pierre_pierre
Re: del.icio.us inaccessible through PlusNet
why dont you look at all the other threads on this same subject.
There is an ongoing discussion available here
I have locked this thread in favour of the other, so all discussion can be kept in one place.
B.
As per the multiple threads on this forum re Rapidshare and Del.icio.us this issue is in hand with our networks team and a fix is planned to roll out tomorrow. In the meantime if you reboot your connection until you get on a different gateway (you can check your current gateway at http://usertools.plus.net/@gateway) you should find that the issue is resolved temporarily.
Hope that helps,
