del.icio.us inaccessible through PlusNet
- Re: del.icio.us inaccessible through PlusNet
17-02-2008 3:40 PM
Is anyone else finding that http://del.icio.us is inaccessible through PlusNet? I can ping the server, but HTTP requests just time out.
The site is working fine when I connect through other ISPs.
Thanks,
Phil
Thanks,
Phil
Message 1 of 4
(911 Views)
3 REPLIES 3
17-02-2008 3:44 PM
why dont you look at all the other threads on this same subject.
Message 2 of 4
(343 Views)
17-02-2008 3:45 PM
There is an ongoing discussion available here
I have locked this thread in favour of the other, so all discussion can be kept in one place.
B.
B.
Message 3 of 4
(343 Views)
17-02-2008 3:45 PM
As per the multiple threads on this forum re Rapidshare and Del.icio.us this issue is in hand with our networks team and a fix is planned to roll out tomorrow. In the meantime if you reboot your connection until you get on a different gateway (you can check your current gateway at http://usertools.plus.net/@gateway) you should find that the issue is resolved temporarily.
Hope that helps,
Hope that helps,
Message 4 of 4
(343 Views)
