data usage is unavailabe
maktoob110
Hello i was trying to see how much data i've used the last month on the website but i get a message saying "
Sorry, there's nothing to show at the moment."
I called customer service and agent told they having an issue showing data usage for sometime now and unsure when will be fixed.
anyone having the same problem? and is there anyway to see how much data was used in the past?
4 REPLIES 4
Browni
Aspiring Hero
Fixes: 60
Re: data usage is unavailabe
If you search the forum for 'usage' you'll find plenty of people with the same problem.
SpendLessTime
Fixes: 86
Lots of people are, and it has been ongoing for a long time.
Just type usage into the search bar and see all the different threads.
No date for a fix and no way to look at your history.
maktoob110
sorry i only looked in the first and 2nd page of the forums
really hope there will be a quick fix for this issue
Jonpe
Fixes: 9
Don't hold your breath, I've been unable to see any usage after 20th July 2016.
Do you have a download limit?
I think it would be good if the service status page could be updated with information about the usage meter; all we have is a note from 12:17 on 20th July 2016 saying it has been fixed.  This is the day mine stopped working!
