customermail4.easily.co.uk POP3 can anyone else connect???
- customermail4.easily.co.uk POP3 can anyone else co...
13-05-2008 6:21 PM
I am trying to connect to a POP3 account at customermail4.easily.co.uk however from here I cannot get connected. If I try various web POP3 test sites they seem to connect ok, and several of my colleagues also connect and receive e-mail without any problems.
Can someone else try to connect to the server at the above address and let me know what they get.
I am trying to find out if it is an Easily problem or a PN problem or something at my end that is causing this.
Thanks in advance,
R.
Re: customermail4.easily.co.uk POP3 can anyone else connect???
13-05-2008 6:36 PM
13-05-2008 6:39 PM
I have received email from this server before, but recently I have received nothing with an error reporting that outlook cannot connect to the POP3 server.
R.
13-05-2008 6:44 PM
But this is the google entry
Can't send email on 3 internet - 3G forum : your 3G community and ...
My domain is hosted by easily.co.uk They have given me both "customermail4.easily.co.uk" and "smtp.easily.co.uk" as the smtp servers, both of which say I'm ...
www.3g.co.uk/3GForum/showthread.php?p=367018 - 120k - Cached - Similar pages
and a lot more like that
13-05-2008 6:49 PM
Try a reboot of router and PC.
Try disabling any firewall or A/V software.
13-05-2008 6:54 PM
13-05-2008 6:59 PM
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Peter>nslookup customermail4.easily.co.uk
Server: resolver1.opendns.com
Address: 208.67.222.222
Non-authoritative answer:
Address: 212.53.95.205
13-05-2008 7:05 PM
14-05-2008 2:28 PM
None of which has helped.
I will continue to try and talk to Easily about the problem, although they seem useless with customer support, I just get the same old check your settings. answer every time.
R.
14-05-2008 2:40 PM
Open a command window by clicking Start > Run, typing 'cmd' (minus the quotes) and clicking OK.
Try telnetting to the mail server:
C:\Users\Bobby>telnet customermail4.easily.co.uk 110
Press enter and what's returned? You should get something like the following:
+OK Hello there.
Next type:
user <your email username>
Replace '<your email username>' with your Easily username. Press Enter, and you should get another confirmation prompt. Next type:
pass <your email password>
Replacing the obvious. Press Enter.
How far through the above process do you get before encountering errors?
14-05-2008 7:07 PM
Yes it's definitely a connection to the POP3 server I am having problems with.
I have been using Telnet to test the POP3 connection from several machines here on my network, all fail to connect.
However if I try Telnet from my server hosted externally, I can connect no problems, and several external POP3 test tools seem to think the mail server is fine.
The thing is if it was something on this computer that is stopping port 110, or generally stopping POP3 access, I would expect all POP3 accounts to fail, but I am receiving email on several other POP3 accounts external to PN.
R.
14-05-2008 8:51 PM
14-05-2008 9:37 PM
Results from nslookup below from both customermail4.easily.co.uk and mail.plus.net,
C:\Documents and Settings>nslookup customermail4.easily.co.uk
*** Can't find server name for address 192.168.99.1: Non-existent domain
*** Default servers are not available
Server: UnKnown
Address: 192.168.99.1
C:\Documents and Settings>nslookup mail.plus.net
Server: UnKnown
Address: 212.159.10.1
192.168.99.1 is obviously my router IP so cannot have it's name resolved.
I can telnet to the plusnet POP3 servers and to an external server at 217.35.90.xxx I run for another company.
As shown below,
C:\Documents and Settings>telnet customermail4.easily.co.uk 110
Connecting To customermail4.easily.co.uk...Could not open connection to the host
, on port 110: Connect failed
C:\Documents and Settings>telnet mail.plus.net 110
+OK Hello there.
quit
+OK Better luck next time.
Connection to host lost.
C:\Documents and Settings>telnet 217.35.90.xxx 110
+OK Microsoft Exchange Server 2003 POP3 server version 6.5.7638.1 ready.
quit
+OK Microsoft Exchange Server 2003 POP3 server version 6.5.7638.1 signing off.
I have concealed the IP of the email server from the external company I deal with.
The only one that seems to be affected from here is the customermail4.easily.co.uk one. It's all a bit strange.
R.
14-05-2008 10:02 PM
Microsoft Windows XP [Version 5.1.2600]
C:\Documents and Settings\Peter>tracert customermail4.easily.co.uk
Tracing route to customermail4.easily.co.uk [212.53.95.205]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms my.router [192.168.0.1]
2 23 ms 22 ms 22 ms lo0.plusnet.thn-ag2.plus.net [195.166.128.93]
3 22 ms 21 ms 21 ms vl604.thn-gw1.plus.net [84.92.4.169]
4 22 ms 22 ms 22 ms linx2.gw.netbenefit.co.uk [195.66.226.150]
5 21 ms 22 ms 21 ms sw-ih-cor-04-outside.netbenefit.co.uk [212.53.64.243]
6 22 ms 21 ms 21 ms customermail4.netbenefit.co.uk [212.53.95.205]
Trace complete.
14-05-2008 10:23 PM
C:\Documents and Settings>tracert customermail4.easily.co.uk
1 Destination host unreachable.
Trace complete.
Not a lot to go on really.
R.
