could this be trafic shaping or throttling?
- could this be trafic shaping or throttling?
18-11-2009 11:07 AM
like a few people around here i have been getting poor connection problems recently. it came to a head monday and i unplugged everything, reflashed the firmware on my router and reset everything.
before doing this i ran tests on hte bt speedcheker and got a 4MB line reported, but in speedtest.net was only ever reported at 0.15-0.44MB/s
on monday night (about 10:30pm) after reflashing i was overjoyed to find i racked up a speedtest.net report at 4.29MB/s (did 4 tests, all reported 3.07-4.35MB/s dl speed)
thinking everything was fixed i was happy this was user error and i had somehow knackered my router but was happy again.
yesterday i ran tests again (exactally the same test, and router hadnt been reset since the 'good' test on monday) and ran 11 tests between 6:25pm and 10:35pm and all of them (on speedtest.net) reported <0.2 MB/s
i dont understand why i am getting such a poor connection (lowest recorded at 0.09MB/s!) on a setup which is obviously capable of >4
also, its not just my DL speed, but also my ping latency. i have attached a report of all the tests i have run showing what is going on
anyone got any ideas?
Re: could this be trafic shaping or throttling?
18-11-2009 12:34 PM
Current line speed:
4500
so seems both BT and PN think it should be ~4M
given this is there any possibilities that i should investigate in relation to filters / master sockets, or if the speed is set as okay its not likely to be a line issue?
18-11-2009 1:17 PM
Sorry to hear you're having problems. I've taken a quick look over your account to see if I can see a reason for this but can't see anything untoward. Your traffic management profile is as it should be, you haven't exceeded your usage allowance, your configured speed both at ours and BT Wholesale's side is fine, the connection seems stable enough and there's no suspicious upload activity.
One thing to consider is the fact that BT speedtester traffic is in the Titanium traffic management queues, whilst other speedtesters will be in the Gold queue. If The BT Speedtester is always OK but speedtest.net and other sites are frequently bad then you may be suffering from the peak time performance problems we're continuing to investigate (although I wouldn't expect speeds to be as low as they are in your case).
If the BT Speedtest is bad too though, then we could be looking at a genuine BT Wholesale line/congestion problem or perhaps something to do the routing on our network. I've made a minor change to your account which should reduce the potential for the latter of these problems to occur.
Reboot your modem/router, keep an eye on things and let us know how you find things over the coming days...
18-11-2009 1:25 PM
will do on the reboot, thanks for the feedback.
is there any explanation why my IP adress is seemingly jumping in every test (even when only minutes apart)?
18-11-2009 2:27 PM
Quote from: deviousrich is there any explanation why my IP adress is seemingly jumping in every test (even when only minutes apart)?
You've had a fair few disconnections over the last 48 hours or so, all will have been assigned a different IP:
Session Ended Session Duration
N/A 15:48:10 (on going)
22:37 17/Nov/2009 0:26:41
22:10 17/Nov/2009 0:8:3
22:02 17/Nov/2009 0:12:37
21:49 17/Nov/2009 0:27:58
21:21 17/Nov/2009 2:48:25
18:33 17/Nov/2009 0:9:24
18:21 17/Nov/2009 19:51:28
22:29 16/Nov/2009 0:30:51
18-11-2009 2:33 PM
sorry for being dense, can you explain what is likely to cause those disconections? i rebooted the router once at about 10:30pm but the logs you show (and in my report) show many many more resets than the one....
18-11-2009 2:49 PM
[quote author="Copper Line Test"]Copper line test:
Test Outcome : Fail
Description : FAULT - probable exchange line card fault
Diagnosis Code: T038
MFL : EX
If you haven't done so already, I'd raise a fault here. When doing so you might want to make reference to this forum thread.
18-11-2009 6:10 PM
incase it helps i have added my router stats below
DSL Parameters and Status
Vendor ID: 00B5GSPN
Revision Number: Y1921a
Serial Number: 123456789abcdx
Local Tx Power: 9.95 dB
Remote Tx Power: 19.79 dB
Local Line Atten.: 21.5 dB
Remote Line Atten.: 13.0 dB
Local SNR Margin: 16.0 dB
Remote SNR Margin: 26.0 dB
Self Test: Passed
DSL Standard: G.dmt
Trellis Coding: Enable
Framing Structure: Framing-3
Config Data Up Down
Intrlvd Fast Intrlvd Fast
AS0(kbps): - - 5504 0
AS1(kbps): - - 0 0
LS0(kbps): 448 0 - -
LS1(kbps): 0 0 - -
RValue: 16 0 16 0
SValue: 8 1
DValue: 4 32
18-11-2009 8:48 PM
Quote from: deviousrich hmm, still bad, and when i visit the fault site you referanced i only get an error page saying a fault has occured (After confirming my tele number step). any ideas?
Looks like that's to do with this which I wasn't aware of at the time
18-11-2009 9:34 PM
well spoted on the status, i'll raise the fault tommorow
given my line is always connecting at "Downstream Speed 5440 Kbps" im still strugling to work out how this could be line related but open to try anything
given my ping is currently at about 800ms i cant really see interleaving making it any worse!
18-11-2009 9:36 PM
18-11-2009 9:40 PM
should i reset the router about this time tommorow? or is a reset not required?
18-11-2009 9:46 PM
Your router stats will tell you if interleaving's switched on. If it isn't this time tomorrow then try a reboot.
18-11-2009 9:51 PM
speed jumped from .012 to 0.7 so definatly had some effect.
lets see if it stableises any higher over a day
thanks for your help, will update tommorow
24-11-2009 12:02 PM
attached updated test report.
Any ideas why this line seems so unstable?
