could someone....
- could someone....
could someone....
28-04-2010 4:02 PM
stats :-
Uptime: 0 days, 0:35:48
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 288 / 6,240
Output Power (Up/Down) [dBm]: 11.0 / 19.5
Line Attenuation (Up/Down) [dB]: 16.0 / 32.0
SN Margin (Up/Down) [dB]: 30.0 / 9.0
Re: could someone....
28-04-2010 4:06 PM
28-04-2010 4:09 PM
28-04-2010 4:44 PM
The fault is showing that an engineer was sent just before lunch, though there aren't any notes following that at present. If we haven't got anything back from them tomorrow I'll call them first thing in the morning and get you an update on what's going on.
28-04-2010 4:48 PM
one he is done can someone sort out my SN margin?
SN Margin (Up/Down) [dB]: 30.0 / 11.5
28-04-2010 4:53 PM
28-04-2010 4:55 PM
28-04-2010 5:11 PM
28-04-2010 5:33 PM
just need my ip profile checking now BT saying its 2000
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,712
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 15.5 / 31.0
SN Margin (Up/Down) [dB]: 21.0 / 5.0
28-04-2010 5:39 PM
I suspect that they (BTw) may have restarted your 'training period' after the exchange work and so your IP profile should sort itself out in the next few days.
28-04-2010 5:49 PM
29-04-2010 8:58 AM
Estimated line speed:
5 - Checked on 2010-04-24 23:01:54
Current line speed:
7150
and BT's Test
is saying i have a 2000 Profile?
Now that your service has now been active for 14 days, we thought we'd let you know the speed as it stands today, by way of comparison.
Estimated line speed: 5Mbps
Current line speed: 7.15Mbps
You can keep a track of your line speed through our website:
29-04-2010 9:05 AM
Hope that helps,
29-04-2010 11:11 AM
